sheathing under paneling?
hollyivy's Avatar
06-28-04, 10:24 AM   #1
hollyivy
I am repairing an exterior wall with old, thick knotty pine paneling. It will be applied directly to a 2 x4 frame wall with fiberglass insulation with the kraft paper moisture barrier. Someone told me that I need to put thermoply (or some other moisture barrier) between the insulation and the back of the paneling. Is this true? What should I use? I have only taken down a small amount of the paneling and I do not want to buy a huge, expensive roll of something. Also, whatever I use can have virtually no thickness.
Thanks!!
chfite's Avatar
SC
06-28-04, 07:15 PM   #2
The vapor barrier in the insulation should be sufficient for your needs.
You would not be able to completely wrap the house from the inside, negating the value of any wrap by leaving gaps. Wraps such as Tyvek go on from the outside of the stud wall, anyway.
