how to stain/bleach wood panelling
Old 07-13-04, 10:20 AM
cmpanska
Hello, is it possible to get a bleached effect on old wood panelling? My 3-season porch has 6 in wide wood panels on the wall. Instead of painting it solid white I'm thinking of staining it so the wood comes through. Thanks
claudia
Old 07-13-04, 11:37 AM
C
I am not sure what you mean by the bleached effect. Can you show me an example?
Old 07-14-04, 08:45 AM
cmpanska
that's the problem, I don't have a photo, it's just in my head. I'm thinking of a whitewashed-cottage look on my 50s-look wood pannelling. I could paint it solid white but I'd prefer a non-even stained or bleached look.
Old 07-15-04, 07:49 PM
C
I would try a pickling stain to achieve the washed-out whitened look. Experiment with it to get just the look you want.
Old 08-26-04, 08:53 AM
mpbro
My house has a lot of previously stained paneling that I'd also like to lighten. I bought a wood bleach kit and will try it on an inconspicuous area.
What is the best way to remove the previous stain? I could sand the flat areas, but the paneling and cabinets have scalloped wood that would be hard to sand. Do I have to just tough it out and get some sandpaper in the grooves, or is there a stain-removing chemical out there?
Thanks,
Morgan
Old 11-06-04, 05:10 PM
Ruth Anne
lightening knotty pinr
One room in our home is all knotty pine. It is quite old, but we would like to keep it. It has darkened over the years. Is there a way to lighten it without sanding down the whole thing? It does have a layer of varnish on it.
Old 11-06-04, 08:43 PM
C
To remove the old color, strip the finish and any stain. Stripping should remove most of the yellowing that results from exposure to light.
Hope this helps.
