Installing Bead Board over Ceramic Tile
I want to install Bead Board in a small half bath in my house and I was hoping to avoid tearing out all the ceramic tile that goes half way up the wall. I know you can glue the bead board instead of nailing it, but can it be glued to ceramic tile? Thanks.
Clean the tile thoroughly and use construction adhesive. You might check through the various versions to see if one is better suited for ceramic surfaces than others.
