Paneling instead of drywall
Old 09-02-04, 09:53 AM
chucknra
Question Paneling instead of drywall
I understand you can panel instead of drywall onto wall studs. I'm finishing out my basement and want to weigh all options (I know it might be more expensive). Is there a certain type of panel or thickness made to put straight on the studs instead of on firing strips or drywall? All information would be appreciated. Thanks.
Old 09-02-04, 10:46 AM
C
You might check the buidling code there. Regular 1/4" paneling on studs is pretty flimsy to touch. Better to put it over sheetrock, unless you can find something heavier.
