Making your own trim
wallyb's Avatar
10-30-04, 12:20 PM   #1
wallyb
I've remodeled my living and dining room and need to trim it out. The old molding I don't like and doesn't match the era of the house. My house was built in 1915 or so. I want to make my own baseboards, without spending a fortune on it. The upstairs trim is about 6" wide with a triim piece on top of it??
Has anyone make their own baseboards? Any suggestions would be great!
Matt
Snoonyb's Avatar
10-30-04, 03:18 PM   #2
Go for it, there are any number of trim pieces that can be successfully combined and for any number of applications, such as crowm, as well as base.
chfite's Avatar
SC
10-30-04, 05:44 PM   #3
My baseboards, circa 1939, are 8 inch with an ogee trim piece on top. The base is solid wood. You should be able to find a custom molding shop in your town to make the trim piece from a standard knife profile, with any luck. You might well be able to get the square base there, too.
If you have a table saw and a decent router, you could make your own. The first hurdle is to decide if buying a cutter for the trim piece is as economical as having a small run made or bought from somewhere.
Here is one site of molding profiles.
http://archmillwork.com/home/am1/smartlist/20/0
Here is a how to site on molding cutting and modification.
http://members.aol.com/woodmiser1/moldings.htm
Hope this helps.
