Which nails for crown molding?
Old 02-22-05, 04:27 PM
I am about to begin putting up crown molding and I am confused as to which nail to us - brad or finishing? And would a 1 1/4 brad be okay? That is the max my gun will hold and I have used it for other trim in the house without a problem, but am not sure about crown. The dryboard is 1/2'' thick.
Thank you for any help you can give!
Old 02-22-05, 04:39 PM
XSleeper's Avatar
No, 1 1/4" is definately not long enough. Usually when nailing crown, the nail goes in at an angle (maybe 30 degrees?) so it needs to be a little longer than what you might think. Generally, a 15 ga. nail that is 2" long should work fine.
Old 02-22-05, 05:35 PM
Thanks for the quick reply. Would a brad work as well as a finish nail?
Old 02-22-05, 07:51 PM
Sawdustguy
15 gauge is trim carpenter nails. In my opinion, the head of the nail is too big and would be too noticable. I would use 1-1/2" 18 gauge nails. I've used it several times and never had a problem. Just make sure you nail into the studs.
Old 02-22-05, 11:46 PM
Mike,
Thanks for the input - I appreciate your help.
