Installing Baseboard into Metal Studs
Old 07-16-05, 09:29 AM
dforward
Hi Everyone,
I am doing some remodeling in our apartment style condo and have run into a situation while installing baseboards. It seems the studs in the wall are not wood, instead they are metal. I obviously cannot hammer the nails through the drywall into the metal studs. I am wondering what the alternatives are. Any thoughts?
Thanks.
Old 07-16-05, 05:24 PM
XSleeper's Avatar
Received 1,963 Upvotes on 1,760 Posts
I'm suprised they didn't install 1/2" osb or some sort of backing for the baseboard to nail to. What was there before? Vinyl cove moulding?
Old 07-16-05, 05:36 PM
C
You can use trim head finish screws such as these: http://************/9yzu2. They are self drilling and will go through the wood base and into the metal studs.
Old 07-16-05, 08:40 PM
dforward
Thanks
It was Vinyl moulding glued to the wall before. I will try those screws and see what happens. Thanks!
Old 07-18-05, 12:25 PM
B
You can usually use construction adhesive and drive nails in at opposing angles with a trim nailer into the drywall.
Recently I saw something about nails that are made to hold in metal studs but cannot find it right now, but they might be an option also.
