Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Paneling and Trim
Reload this Page > crown moulding inside blunt angle problem
Old 07-18-05, 06:39 PM
tubbie
crown molding inside blunt angle problem
I have almost finished crown molding in my bedroom. The key word is almost. I ran into a problem with an inside 130 degree blunt corner. I can't figure out the angles on the compound miter. I would appreciate any help. Thanks.
Ty
Old 07-18-05, 08:31 PM
XSleeper's Avatar
Try these charts: http://www.altereagle.com/Crown_molding.html
click on the appropriate chart. Maybe the angles listed there will get you closer than guessing. Your crown is probably getting shorter and shorter!
Old 07-18-05, 09:23 PM
tubbie
I just checked out the sight. It looks like that may do it. I will try it and let you know. Thanks for the help.
Ty
If anyone else has any ideas, please let me know.(Just in case the chart doesn't work)
Old 07-19-05, 10:18 AM
XSleeper's Avatar
BTW, 130 sure is an odd angle, double check it. Most framing is either 120 or 135.
Old 07-20-05, 01:27 AM
tubbie
you're right. it is 135 degrees.
Trackbacks are On
Pingbacks are On
Refbacks are On
