Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Paneling and Trim
Reload this Page >
What type of nails to use for crown moulding
Old 08-23-05, 01:31 PM
jconcep
what size/type nail are best for crown moulding? also is it best to use a nail gun or just a regular hammer with pre drilled holes?
Old 08-23-05, 04:03 PM
C
Usually number 6 or number 8 finish nails, depending upon where on the molding it is being nailed. Using mounting blocks would affect how it is nailed. A brad or finish nailer is less likely to mar the wood than would a hammer.
Old 08-23-05, 04:35 PM
KenTheHandyMan's Avatar
The predrill/hammer method will also take a lot longer. A word of warning though, be careful near the ends of the trim. If you're dealing with a hardwood, like oak, you might want to predrill and hammer there.
I cope inside corners of crown, so I can stay away from the end 6 inches with no problem. On the outside corner though, I use wood glue and miter clamps. This keeps the corner tight. If there is blocking in the ceiling, you can nail into that (or ceiling joists, if available).
In any case, use your metal nail set to roll the outside corner once it's in place. This will make any gap between the two pieces, disappear.
