How to cut trim???
Old 10-17-05, 06:20 PM
passionberry73
How to cut trim???
I need to cut molding for around a door and window, and I have what I think is called a compound miter saw? Anyway, it can be put at different angles...what angles do I need to have it on to make the corners fit together? And lets say Im going to cut the piece that goes up the length of the door first, and then over the top...??? Do I need to reverse this for the opposite side? :mask:
Old 10-18-05, 06:51 AM
Received 875 Upvotes on 766 Posts
The wood trim is usually cut at 45 degrees - left hand or right depending on side.
