Which miter saw blade?
Old 11-08-05, 01:18 PM
Rick P
I'm going to install some moulding around the house and I need to know which saw blade to buy. I'm not sure if the moulding will be MDF or primed Pine.
I have a 24 tooth blade now and it cuts pretty smooth if I go slow. I really don't want a dedicated blade for trim/moulding as I won't be doing much of it. Will a 40 tooth blade suffice? or do I need to get a 60 or 80 tooth blade?
Old 11-08-05, 03:55 PM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
Generally, the more teeth there are the finer the cut. But it also depends of the set of the teeth, so you will want to look for a blade that says "fine crosscuts" or something to that effect on it, which will help you purchase a half-way decent blade for finish work. (You don't want a carbide blade that's meant for ripping.)
Avoid the thin carbide blades that Dewalt sells- they have a tendency to vibrate too much. A thicker blade will be often more stable than a thin blade, especially if it has built in features for stabilization.
