Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Paneling and Trim
Reload this Page >
Crown install with window all the way to ceiling...
Old 11-11-05, 09:13 AM
vincentblack
I have an arched window that extends almost all the way to the ceiling ; the apex of the arch is about 2inches from the intersection of the wall and ceiling.
The crown i'm using is installed on a line 3in down the wall from the previously mentioned instersection. If I install the crown as I have been, it will overhang the window opening by an inch or so and look ugly.
What does a person do in this circumstance? Thanks in advnace.
Old 11-11-05, 01:24 PM
XSleeper's Avatar
Received 1,960 Upvotes on 1,757 Posts
You have 3 options.
1). End the crown short of the window, putting a double 22.5 return on each end.
2). Run the crown right past the window, and install a filler (extension jamb)behind the crown that will butt up to the window in some manner.
3). Have the yahoo who designed this problem get the window removed and reinstalled about 4 1/2" lower. Unless the "yahoo" is you, in which case, ignore #3!
