Need to fix a gap!
Old 11-13-05, 09:00 PM
edge13
Need to fix a gap!
When my house was built, my builder left a 3/8 gap on most of my door jams and casings..from the floor. The flooring is hardwood and the initial trim is paint grade trim that is white.
I am considering repairing this myself. What would be the best way to repair this so as to hide the seam of joining the two pieces of wood together?
Old 11-21-05, 02:29 AM
edge13
34 views and not one suggestion?
Old 11-23-05, 10:24 AM
lizutah
I have the same issue
I have the same issue in my bathroom. I supposed I need to redo it. Hopefully it's not to hard good luck.
Old 11-25-05, 02:23 PM
Its being paint grade would enable you to get a piece of the one piece door casing and some molding and cut a sliver off and attach it to the bottom of the existing work. Some creative work with some glue, spackling compound, and paint should solve the problem.
