Ever used POWERGRAB by loctite?
Old 12-01-05, 06:57 PM
BIGJIM05
Has anyone ever used PowerGrab by Loctite?
I tried using It to hold a small piece of molding to a wall and after being braced 18 hours the thing still fell off.
Would anyone please recommend something beside Nailing that will hold molding to a wall?
Thanks
Old 12-07-05, 06:31 PM
susanmc180
try f-26 construction adhesive
or liquid nails.....................make sure you follow instructions and "butter" both pieces to be glued.butter them both then wait a few minutes until it starts to set.then just stick together and weight it or pry upon it w/ anything you can walk away from that will have pressure against it.presto,it will be there for a long long time.
matt mcshane
littlerock arkansas
Old 12-14-05, 07:36 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
Powergrab
I agree with Matt, Liquid nails is excellent. I have used PowerGrab successfully many times, and don't recall any problems. It may have been due to an improperly prepared surface, or releasing pressure prior to the minute or so required to form a bond.
