Crown Molding (where to nail)
Old 01-06-06, 06:53 PM
Arrow Crown Molding (where to nail)
Does crown molding normally get attached to the walls (2x4s on side) or the ceiling (joists) via nailing?
...or both if possible?
Old 01-07-06, 12:41 AM
nailing
For walls with the joists perpendicular you nail to both studs and joists. For walls parrallel to the joists you'll need to install blocking.
Old 01-07-06, 11:28 AM
Peladu's Avatar
The top 2 ˝ inches of a wall should be solid wood. (double top plate)
If your crown extends more than that, find a stud.
For the ceiling, I am assuming its existing so adding backer blocks would be impractical or impossible. So either find a joist and if the joists are parallel then try “toe-nailing” it through the sheetrock.
The hardest part of Crown Molding is cutting the corners.
Good luck to you.
Trackbacks are On
Pingbacks are On
Refbacks are On
