outlet marking for paneling
I am installing a traditional raised panel system around my entire interior and I have quite a few outlets to cut around, I have searched for some type of product to mark my outlet so that Ican press the panel against as a guide for cutting and cant seem to find anything. Is there such a product out there, like a removable marker color that will stay wet as I press the panel against the outlet?
thanks
thanks
my 2 cents
Hi
when i had that problem is what i used and work fine.
Get a outlet box to used as patern
1. take 2 drywall screws and screw one in each hole of the outlet box.
2. cut the screw part off and file them sharp
you can do that before inserting the screws in the hole
3. aling your panel and them simply press on them and there you will have 2 pin mark behind and all you need is to place your outlet box on the mark and trace out the patern of the box.
