Wainscoting and chair rail
Old 12-20-06, 07:46 AM
I'm installing a few sections of wainscoting in my kitchen eating area. I will remove the baseboard molding and install.
Do I nail the chail rail over the wainscoting, or just on top of it (butting against it?)
Old 12-20-06, 09:41 AM
It depends on the type of chair rail you buy. I prefer the kind that overlaps when using wainscotting.
Old 12-20-06, 11:17 PM
Marksr is right; a wainscot cap is much easier. A wainscot cap looks like a chair rail with a rabbet cut in the bottom so it fits right over the top of the wainscot. If I do a bead board wainscot I like to install the cap first. I set it to height and dead level. With the bead board cut square all you have to do is check for plumb every so often while you nail it off.
If you try to just set a chair rail on top you'll probably wind up with a ragged edge showing. You can nail a chair rail to the front but then you'll have to make something to cover the top. If I have to go that way I use my router to cut a decorative edge on some 1x and then rip it to width.
