Removing paint drips from wood stained baseboards?
inagf2's Avatar
06-24-07, 12:36 PM   #1
I recently moved into a house that has wood stained baseboards throughout. I couple of the rooms were VERY poorly painted, leaving many drips and smears on the wood stained baseboards. Does anyone have any suggestions for removing the paint but keeping the wood stain? I don't really want to remove the baseboards and refinish them.
Thank you.
marksr's Avatar
TN
06-25-07, 04:04 AM   #2
Welcome to the forums
You might try a product like 'oops' or 'goof off' and see if it will disolve/remove the offending paint. Often GENTLY scraping off the paint drips/smears is the best solution. A light sanding and another coat of poly may be needed once you have the base clean.
retired painter/contractor avid DIYer
