What is the best way to measure angles when replacing trim?
I've decided to replace all of the trim in my home.
Since I have no experience with measuring angles I am wondering how best to do this.
I am using pre-primed mdf board so little mistakes can be hidden with caulk and paint.
I googled my question and came up with a place http://www.compoundmiter.com that seems to have the problem solved for us novices. Not cheap but if it saves time and money on materials it is worth it to me.'
Anyone want to offer their advice before I open up the wallet?
Thanks!
Thanks!
If you're doing the entire house, invest in a a compound miter saw. You can get a not-the-top-of-the-line saw inexpensively enough, and keep it or sell it for most of what you have invested. A coping saw will be necessary for all inside corners, since no room has been built square in history.
Not what I meant...
I guess I wasn't very clear in my post.
I already have the saw...what I want to know is how best to measure the angles. Clearly 45's are done by sight. It is the other angles that are a problem.
Save and Mark the old trim as you take it down and reference them when it comes time to replace that section. That will give you all the angles. then just put it on your saw and turn the blade to match the angles. It also may be helpful with your length measurements.
Good idea, czizzi. Most of the angles will be 45 plus or minus. Others will be 22.5 in bay windows. If the angle varies a little, that is why you will be coping the ends. Never install inside molding trying to cut it at an angle. You will go mad.
Often the trim/casings around doors/window leave a 1/4" reveal, so what I do (was shown this once) is to use a carpenters pencil, the flat kind or any other piece of 1/4" wood place it against the face of the frame on edge and mark a line on the verticle then on the horizontal - both sides, then you have a mark to measure the length of your 45 degree (short to short as they say). Once the top is in, the side casings would follow that 1/4" reveal down to the floor (doors) or bottom of window..
If that makes sense...!!
Coping anything that is paint grade is just silly. Sure if you do it right it will look good, but it is a waist of time, and you can get the same look with a little caulking. Even when we cope in finished wood crown we still caulk the corners, it allows for movement in the wood.
Plus you will get a much better glue surface using miters. I also recommend using some kind of construction adhesive behind all your trim. This will also help prevent your joints from breaking over the years.
As for the angles, you shouldn't have too much trouble. Most will be 45 or 22.5, and sometimes 30. If you run into something that isn't 45, use your scraps to test out the angles.
A quick trick for baseboard. Depending on how bad your walls are.
Cut your inside corners a 44 deg. This will leave a small gap in the back, but will ensure that the front is closed up.
Cut your outsides at 46. This will again leave a gap in the back, but close up the front. Then a little caulking can fill in the gap. This will save you a lot of time.
Good Luck
Good Luck
Good info ..and tips. It all comes down to - how square are your walls, where base meets each other.. and some 'finagling' on the corners.
No wall, that Ive encountered, is perfectly square. So it will take some adjustments/angle cuts, etc. to get it Right.
As mentioned, caulking can (and does) a wonderful fill for the odd joints.....!
'You can do it, we can help' .... (ahem...!!)
Hey, it ain't so, you CAN MITRE INSIDE CORNERS, and do it with good results.
Use a couple scraps to set your saw to the proper angle. Then after you have cut the first corner piece DON'T nail it into the corner, leave it loose. Nail at first stud out, but NOT the corner stud. Then apply some wood glue to the mitre, of both pieces, PUSH into the first piece, nail the second and let the glue hold the mitre. It will then hold tight and the floating action will keep it such. Caulk any gaps between the trim and the wall.
Been doing it for years.
Dale in Indy
Dale in Indy
This has to be the easiest tool to get your exact angles, but it comes at a $110 price tag. Well worth the money if you do enough trim.
http://www.toolmarts.com/bosch_dwm40l.html
Angles
Use an inexpensive device similar to this one:
http://www.rockler.com/product.cfm?page=5362
Transfer the angle to your mitre saw and you are "good to go."
I found a similar device at the local home center. Measure the angle and tighten the wing nut.
Here is the link http://www.skiltools.com/en/AllTools...DAF&cid=193817
FYI. It is $50 less then the Bosch, and Skil is a sub of Bosch, so there must be a reason for it.
Empire makes a little yellow plastic protracter device that I have found to be very helpful in measuring angles. I bought it at one of the big box home stores. The angle markings are a bit on the small side to read, but it does get me in the ballpark. If I am really not sure of the angle, and I am staining the wood, I will use some scrap trim and make a few test cuts. It is time consuming, but the results are worth it.
