Remove Paneling
Old 07-29-08, 12:59 PM
Remove Paneling
I have laminate paneling and would lke to remove it. Is there a way to do this or will I need to put-up new sheetrock?
Old 07-29-08, 05:25 PM
How was the paneling installed?
If it is just tacked on, it will be easy to remove. If it was glued on you may have trouble. To remove glued on paneling you need a stiff broad knife to try and scrape off the paneling and glue. The odds are you will need to do a lot of drywall repair after the adhesive is removed - possibly skim coat. Installing new drywall won't be cheaper but it might be easier/quicker. It all depends on how the paneling comes off.
