MDF vs wood wainscot panel
Old 08-03-08, 06:54 PM
I'm considering beadboard panels in my bath room for wainscoting. Wall is next to (2" from) tub, no shower. Panels will go over plaster. What material would be best to use?
Old 08-03-08, 09:57 PM
C
I would use plywood panels. Easier to flex to fit any irregularities in the wall, lighter weight, will go up with nails.
Old 08-04-08, 04:27 AM
Received 873 Upvotes on 764 Posts
It wouldn't hurt to prime [or poly] the edge and backside of the panels closest to the tub.
Old 08-04-08, 09:12 AM
OK, thanks for your advice, chfite and marksr. I wouldn't have thought of priming the edge and back--good idea!
Old 08-04-08, 09:21 AM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Pretty sure they also have PVC wainscot now. Pre-finished white but still paintable if you want. No water issues with it.
Used to be available at the Box stores, but haven't looked in that area in a while.
Old 08-24-08, 04:17 AM
L
I just gutted and remodeled my bath at the end of last year and used Plastpro vinyl wainscot planking found at home depot for the lower four feet of the walls and have no complaints with it =).
Btw if you plan to paint it like I did you will want to give it two coats of a quality primer and two coats of a good paint and I suggest using a brush over a roller.
