Remove sealant on trim
When I went to paint our white window trim a dark color, the paint wouldn't stick. It became obvious that the previous owner applied some sort of clear sealant (most likely to deal with a problem with the windows leaking). It's not caulk, as it covers the face of the trim, stop, etc. and is very thin; not something I can peel off.
Any idea what he most likely used, and how best to remove it?
Sanding isn't a good option because the trim and stop are colonial with a lot of grooves that would be hard to preserve. Perhaps some sort of chemical sealant/paint remover would do the trick?
Any suggestions? Thanks.
You might try and see if a deglosser will wash off the contamiment. Be sure to fold or change the rag out enough so you don't loosen it and just smear it around. You'll want a little fresh air ventilation too.
