what should I do about my baseboard molding that is 3/4" thick ???
I put new door casing's on all my interior doors, now I am doing the baseboard trim, the problem??
The baseboard is 3/4" pine while the door casing is 5/8" thick. So when I but the baseboard against the casing, not flush.
Shall I rip the 3/4" to 5/8" or can I bevel the edges and have a smooth, nice looking job?
What do you pro's do? I assume you use baseboard that is 5/8" thick. I am trying to match it with the rest of the trim in the home, you know.
DanO
DanO
The simpliest thing to do would be to install plinth [sp?] blocks at the bottom of the casing. Normally you would use lumber a little thicker than the base/casing and make it just a little wider than the casing and little taller than the base, but it might look fine with 3/4"
When the baseboard is thicker than the casing, you bevel the ends of the baseboard, cutting a 45 degree angle on the ends of the baseboard so that the two meet at the corner of the casing. Yes, it would have been better to use thicker casing, or to have gotten thinner baseboard. If you're set on making what you've got work, that's what I'd suggest.
