How to make use of excess window trim
Old 12-17-08, 06:09 PM
After installing new windows and trims around them, my contractor is left with about 100 ft. of window trims. I could buy it from him, but don't know how to make use of this excess trim, other than storing them as replacement in the future. Any other design idea?
Old 12-17-08, 08:13 PM
XSleeper's Avatar
It's often nice to have the same profile of casing used throughout a home. So if your door trim does not match your window trim, maybe you could use some of it there. Otherwise your contractor will find a place to use it before you will.
If it's an unusual profile, it might be nice to keep a few pieces in the event you need to match it in the future.
Old 12-18-08, 01:33 PM
chandler's Avatar
Yeah, don't shop like a woman (oops, I'll catch it for that one), buying something because it's there. In most likehoods, you will run over it with the lawnmower or break it before you ever find a use for it, not to mention moving it a hundred times. And molding changes very little, so it is readily available whenever you are in need. Unless you have an immediate need for it (within 3 months) let the contractor deal with it.
Old 12-18-08, 01:50 PM
Gunguy45's Avatar
Super Moderator
Buy 10-20 ft, unless you have a specific need, and let him use the rest. If its stock stuff from a yard or Home Center...nevermind.
Sounds like he way over estimated what he needed.
Old 12-18-08, 06:03 PM
Thank you all for the suggestions. Here's how the story goes. Apparently the contractor ordered 380 ft. of the trim after taking 15% waste into account. However, since it was a special order (Douglas fir) the lumber yard could only deliver him in the units of 500 ft. I am told that one can't just walk into a store and find Douglas fir trim that easily. So, there's indeed some value to get these. As XSleeper suggested, since the door trims are different I may find some use of this around the doors. But that's a project for the spring, for now I have to find a place to store so that they don't get "run over it with the lawnmower or break.... not to mention moving it a hundred times". So true!
