Basement door/window trim, ceiling to low....
dcanesdbs's Avatar
01-01-09, 08:08 PM   #1
I have a slight dilema.... I am getting a dropped ceiling installed and I noticed the door and window trim where the ceiling drops will be VERY minimal... I see for the doors, I see an inch if that where I can put trim. For my windows, it actually extends passed where the trim would be! Awwww... Can anyone tell me what my options are on how to trim to doors/windows where the ceiling ends...
Thanks
marksr's Avatar
TN
01-02-09, 04:26 AM   #2
You can run the side casings straight up to the drop ceiling grid. If you need trim above the door, use a piece of 1x ripped to the right size and then run your casing straight into it - no miter cuts
retired painter/contractor avid DIYer
dcanesdbs's Avatar
01-02-09, 07:27 AM   #3
Posted By: marksr You can run the side casings straight up to the drop ceiling grid. If you need trim above the door, use a piece of 1x ripped to the right size and then run your casing straight into it - no miter cuts
Marksr,
You are saying use normal trim on the sides of the door but for the top are you saying to cut it to fit? Would that look stupid?
marksr's Avatar
TN
01-02-09, 02:19 PM   #4
For the top you could use a 1x, ripped to fit and as long as the cased opening is wide. then the casing on each side would go straight up to the 1x. The 1x will probably be a little thicker than the casing [it could be planed down a little] but once it's all caulked and painted, it should look fine.
