adding door trim to a crooked wall
catty9's Avatar
01-14-09, 11:14 AM   #1
I just added a door in a hallway that had crooked walls. We had to shim the door frame to get it plumb. But now if we put the trim along the door frame there is still that extra space between the wall (a good inch) and the frame. How should I cover up that space? It's triangular, being about 1 inch at the top and tapering down to 1/4 inch about 6 inches from the bottom of the frame.
XSleeper's Avatar
NE
01-14-09, 11:22 AM   #2
Not sure if the jamb is sticking out past the wall or if it's recessed into the wall- can't tell by your explanation... but the only thing you can do is to scribe a taper on a piece of wood and add it onto either the door jamb as an extension jamb... or add it onto the back outside edge of your casing... depending on which is needed.
drbob's Avatar
01-14-09, 02:59 PM   #3
If I am understanding you correctly - standard door trim is 2.25 inches wide and should cover it fully. If I am not understanding you, please add some additional detail and I will be happy to try and help.
