Trim around heat registers
Old 03-13-09, 05:24 AM
B
Post Trim around heat registers
I started putting new trim in the living room. After completing it I think it looks a little funny to me. I cut at a 45 deg angle into the register. Is there anything I can do to make this look better? Am I being too critical and merely painting the wood would make it look better? If this is what I do I'll have to do the finish the rest of the house like this.
038
Old 03-13-09, 06:17 AM
XSleeper's Avatar
Received 1,963 Upvotes on 1,760 Posts
I wonder if that is a cold air return, and if so, you need a 7/8" thick box style cold air return grille like this.
Otherwise if it is a heat register, you could use one like this.
