Baseboard measurement from concrete floor...
I took everyones advice and am having the baseboards installed in the basement before the pad and berber carpet is installed. The carpenter is going a half in drywall pieces)
I was looking in the one room and the baseboard looked higher in the one area than the other, from the wall. I thought maybe my eyes were 'tricking' me. Well I took the measuring tape and it looks like the one section, to the left, is actually 3 forths and as I go down to the right it is half inch. I think the floor might not be level? If this is off like this, will I have a problem when they install the pad and berber carpet? Will there be a slight gap from the on area?
Should I mention this to the carpenter that is putting up the baseboard. Should I be concerned? Is there anything the carpet installer can do to make sure there isn't any gap (place the pad under the baseboard or extra paddinng in that or those areas where it is a little higher.
They should trowel on floor leveller. And they should be told about this in advance since they likely did not bargain for that, might not have floor leveller with them when they come, and it will slow them down if they are the ones that have to do it.
Should I bring this up to the person installing the baseboards? Can he do anything now since they are nailed? he still has a few more rooms to do.
Baseboard goes on straight. When the floor has dips, the dips get filled in, period.
You mention the carpet layers didn't want the base on. This is not an issue, it is standard to have the base on, so don't let them tell you otherwise. They just want a shortcut so it goes faster. Don't be surprised if they make a few knicks here and there, however. that's to be expected.
