Finishing Knocked Out Wall
Old 07-14-09, 01:53 PM
A
Hi everybody!
My husband and I tore out a wall between our kitchen and living room
but now we have the problem of covering the gap where the wall once was. We plan to do sticky tile flooring for now to save $$, but we're wondering what to do about the raw area that is now exposed plaster.
here's a before photo
and after. from the dining room
We've since painted the cabinets white.
I'm contemplating using salvaged lumber for the trim but I really have no idea what to look for. We have a salvage barn, but I wouldn't know what to ask for when I go in.
Any ideas and suggestions would be much appreciated.
The home was built in 46 and has a good bit of character. Lots of wood around the rest of the house, as you can see in the before photo.
Old 07-14-09, 02:23 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
Well, since all your jambs appear to be stained, I'd use 1 x 6 and stain it to match then case it with the same type you have around the doors.
Its either that or sheetrock, corner bead and mud..then paint to match the walls. If you plan on keeping the wood trim..use the stained wood..if you plan on painting the trim in the future..then rock it up.
Just a DIY opinion..no Pro. Personally..I like wood.
Old 07-15-09, 04:08 AM
Received 870 Upvotes on 761 Posts
What do plan to do with the electrical?
Old 07-15-09, 06:44 AM
A
thanks Gunguy, that's about what we'd thought.
Mark, these are old photos. The electrical has already been pulled out entirely and the lines rerouted.
Anybody have any experience with salvaged materials on a project like this?
Old 07-15-09, 06:51 AM
T
Just treat it as a large door opening. Use either poplar or pine for the trim and take the time to match the profile of the existing wood trim in the house as well as the stain color. I'm sure it's not, but you might want to check to see if that is/was a load bearing wall.
Old 07-15-09, 07:39 AM
A
Thanks timber, we will treat it that way.
I had a contractor confirm it wasn't load bearing before we tore it down ourselves.
I was thinking of something like the trim in this photo which is salvaged, but am not sure of the extra challenges I suspect it poses.
Old 07-15-09, 01:30 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
From what I see on the original door, there was fluted molding with rosettes and plinth blocks. Close?? I would go back with a 1x6, trimmed to 4 9/16" and case the opening and use the fluted molding, rosettes and plinth blocks back in the same location.
