To sand or not to sand.
Old 06-30-10, 09:43 AM
H
Smile To sand or not to sand.
What is the easiest way to paint over paneling? To sand or not to sand..?
Old 06-30-10, 10:36 AM
Received 1,273 Upvotes on 1,213 Posts
Welcome to the forums!
Like kinds of paint don't generally requiring sanding. If you're going from oil to latex, a good oil based primer would be a good idea.
What kind of paint do you plan to use and where will you be getting it?
Old 06-30-10, 01:33 PM
Received 850 Upvotes on 746 Posts
A light scuff sanding is almost always a good idea. If this is unpainted [but has a factory finish] paneling you'll need to use a solvent based primer first. Latex is fine for the top coat. Expect to need 1 coat of primer and 2 coats of finish.
Old 06-30-10, 02:10 PM
Mark thinks sanding is more important than I did - I would take his opinion over mine and scuff sand
