white board walls
Old 01-02-01, 02:48 PM
Guest
I would like to build a wall that is a white board. I vaguely remeber that it is as easy as painting a smooth surface with "white board" paint. Can anyone offer some guidance? Thanks.
Old 01-09-01, 11:17 PM
some help
Hello
I know of two co. that you can get if from..Willson Art and Formica....they each have wall panel that is not made for counters but for what you need...I have used it bathroom for years...
Old 01-15-01, 12:10 AM
Guest
I have used "black board" paint before to turn a smooth surface into an erasable chalk board. I have not run across "white board" paint that will do a similar trick resulting in an erasable markerboard, which I think is what you are hoping to do. Check with a local full-line paint supplier (Sherwin-Williams, ICI, etc.) - if "white board" paint exists, I'm sure they'll have it or be able to get it.
Good luck!
