removal
Old 01-12-01, 05:30 PM
Guest
I just bought a house that has cheap paneling in every room is it possible to remove it without resheetrocking I am not sure if it is glued but figure it probably is. thanks mike
Old 01-13-01, 04:28 AM
some help
Hello
You think it may be glued and I think if its cheep paneling it may not be. You need to try and remove a sheet and see what is going on....But if it is glued the most you have to do is remove the glue and float the wall with taping mud and re-texture to match the rest of the house..Good Luck..
