Question Regarding Filling Nail Holes In Pre-Finished Trim
nickhaake's Avatar
IL
03-28-13, 09:49 AM   #1
Hello Everyone. I'm remodeling my first home and just about finished with the family room remodel. My wife and I decided on casing, base and crown moulding for the room. However, my question for everyone is how I should fill the nail holes and paint over them afterwards. I selected the mdf pre-finished moulding from a home improvement store since the mdf has some flexibility (to allow for some uneven walls). After I've got them nailed in, how should I go about filling in the nail holes and then painting these pre-finished gloss white pieces?
The satin white paint is not sticking to these pre-finished boards so I'm not sure what to do to cover the nail holes and seems.
Any advice would be greatly appreciated. Thanks!
Nick
marksr's Avatar
TN
03-28-13, 10:05 AM   #2
Welcome to the forums Nick!
Not sure why your paint won't adhere but I've never worked with prepainted MDF. I think all MDF comes preprimed and it paints great. Anyway, if you go to the section of the store that sells colored putty, you should be able to find a jar of white putty - that's about the best you can do without painting the trim.
retired painter/contractor avid DIYer
stickshift's Avatar
WI
03-28-13, 11:40 AM   #3
So you're trying to paint them and it's not sticking or the paint which came on them is coming off?
If the latter, I would go back to the store where you bought them to see what they advise. If the former, I would scuff sand first and then paint again. Only do this on a little bit though at first in case that's not enough. If it isn't, I would scuff sand and then apply an oil based primer and then paint.
nickhaake's Avatar
IL
03-28-13, 01:05 PM   #4
I tried to paint them with a satin finish white paint and the paint seemed to just bead up on the boards. It reminded me of rain beading up on a freshly waxed car. The satin paint just isn't sticking at all to these pre-finished mdf pieces. I spoke to an associate at the home improvement store in the paint department. He said a satin paint will not stick to a gloss finish. He basically told me "you can't go down a sheen with coats of paint." He said my options were to sand every piece or put a coat of primer on them.
The problem I have is that they're already nailed to the walls. Is my only option to CAREFULLY prime them while on the walls?
Gunguy45's Avatar
Super Moderator
AZ
03-28-13, 01:10 PM   #5
Just to be sure...are they MDF or plastic? I too have never seen gloss pre-painted MDF moldings (and I sold the stuff for 5 yrs). Primed yes...but not gloss paint. The plastic stuff does have a gloss finish and needs to be scuffed if they will be painted.
Where did you buy? Could you link to the product or provide a brand?
You could carefully scuff them using a fine sanding sponge and see if the paint adheres then.
Vic
"I sometimes wonder how some people ever made it to adulthood..."
stickshift's Avatar
WI
03-28-13, 02:45 PM   #6
I agree with what you were told, scuff sand and primer would be what I'd do. Bummer, this is going to be a lot more work than you thought it would
marksr's Avatar
TN
03-28-13, 03:46 PM   #7
There is no reason a satin enamel won't adhere to gloss enamel that has been sanded! I've done it more than a few times and never had any issues. You'd only need a primer if you were covering an oil base enamel with latex enamel.
Vic makes a good point - is it plastic trim? From your description it sounds like the trim has either a wax or oil film on it - no paint/primer will adhere well until that is removed. Clarification as to just what product you have would be nice.
nickhaake's Avatar
IL
03-28-13, 04:49 PM   #8
Gunguy45, I can absolutely provide a link.
This is the item I purchased in both 8 and 12' lengths from Menards.
11/16" x 3-1/4" x 8 ft. Prefinished White Crown Moulding 51 at Menards
They also sell this same material in casing and baseboards, which is what I purchased. So at this point my options are to either lightly sand everything after it is installed on the walls before painting with some satin paint, OR remove the boards from the walls to sand and paint.
Great...
Last edited by Gunguy45; 03-28-13 at 05:24 PM. Reason: To make link easily available.
Nashkat1's Avatar
VA
03-28-13, 07:18 PM   #9
The description says MDF but it looks like plastic in the image.
nickhaake's Avatar
IL
03-28-13, 08:13 PM   #10
Yeah, I agree that it definitely looks like plastic but I assure you that it's MDF. It's actually MDF wrapped in some kind of film that is painted.
marksr's Avatar
TN
03-29-13, 03:44 AM   #11
The product description says prefinished white but the MSDS links says a SWP flat latex primer
I'd guess that the MDF is wrapped in some kind of plastic or vinyl coating. You might try wiping a piece of scrap with a liquid deglosser and see if that will harm the coating. If it doesn't it should make it paintable. Getting some white colored putty may be your best option.
