Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Paneling and Trim
Reload this Page >
Putting up paneling in a bathroom. Is this stuff ok to use?
Old 12-17-13, 10:28 AM
G
House of Fara 8 Linear ft. MDF Overlapping Wainscot Paneling Kit-32MDFKIT at The Home Depot
Anything else I need to keep in mind when adding this to the walls? Apply adhesive in an S pattern and staple the corners and seems.
Old 01-13-14, 12:47 PM
N
I would use the red oak and paint it or stain it - not that much more expensive and from what I was reading about MDF - it doesn't hold up well in moisture - mixed reviews.
Old 01-13-14, 01:37 PM
chandler's Avatar
Received 11 Upvotes on 10 Posts
These are 6" wide slats with an overlap, so it is not a "panel" as you may think. Just for clarification. I would go with a primed wood wainscoting panels (definitely not oak - grain raises too much) and independent slotted base and chair. You may come out a little cheaper and would not have to deal with slats, if I am reading their description right.
Old 01-13-14, 01:42 PM
Gunguy45's Avatar
Super Moderator
Received 8 Upvotes on 8 Posts
One big this is in the specs "moisture resistant-no". I'd either go with real wood primed and painted or the PVC stuff that they have.
If this is a 1/2 bath it might not be as big a problem.
