Replacing T&G Solid Wood Paneling with Drywall
stikstikly's Avatar
ME
06-28-14, 06:57 PM   #1
I currently have solid tongue and groove wood paneling in my living room that I'd like to remove and replace with drywall in order to update the look of house. I've peeled back some of the trim to see what I'm dealing with. The problem is that the wood that I'm removing is 7/8" thick. The max size drywall I've seen around here is 5/8". This leaves me with a pretty sizable gap between the future drywall and the current trim/moulding/baseboards/ceiling beams. Any ideas on how to resolve this?
This picture shows the trim removed from one of the doors and the t&g wood to be removed beneath:
XSleeper's Avatar
NE
06-28-14, 07:40 PM   #2
You could always rip 3/8" plywood into strips then use it as furring to shim the framing out for 1/2" drywall. Use a staple gun to attach the furring.
marksr's Avatar
TN
06-29-14, 03:13 AM   #3
Like X, I'd either shim out the studs and to 1/2" drywall work or if I didn't have the time to spend on that - laminate the walls with 1/4" drywall and recut the trim to fit.
btw - welcome to the forums!
retired painter/contractor avid DIYer
stikstikly's Avatar
ME
06-29-14, 01:20 PM   #4
Perfect! Thanks to you both.
