IL
08-13-14, 08:56 AM
Quarter Round Basement Options?
basement room. There was wood trim, but no quarter round moulding at bottom. The room was carpeted and the carpet filled the gap. I removed carpet, down to concrete. Now there is a gap.
What type of quarter round or something similar should I install here? I was thinking something rubber or pvc as it will be in direct contact with a cold basement floor.
Thanks
Thanks
NC
08-13-14, 09:02 AM
Yes, I think PVC molding would be a good idea. Also, you don't "have to" go with 1/4 round as it may be difficult to attach. Shoe molding or some other profile may be tall enough to allow you to nail it to the base molding above.
MO
08-21-14, 08:08 PM
All kinds of options here. just find a trim that will have enough height to attach with nails. when you install it just shim it up with 1\8" stock to keep it off the floor. then remove the shims. You may need to shim out the gap between the floor and the drywall so the new trim dosent roll.
