Staircase trim question
Received 0 Votes
I live in a split level house from the 70s and it was carpeted wall to wall. I removed the carpet from the stairs and in doing so damaged the piece of quarter round that goes along the staircase where it meets the wall.
Its a total eye sore the way it looks now and I just wanted to know what do you think I should do. Should I replace with a new piece of quarter round? Or go on the advice of a contractor who worked on my house one day...don't bother just patch the wall, sand and paint.
I attached pics for you to see..Thanks
IMO that would probably look best if you could avoid any trim there. Sand that drywall so it's smooth, skim if needed, scrape and sand any paint/caulk residue off the top of the skirt, caulk the seam where the drywall meets the skirt and paint it.
But I guess you have that wall cap below it, don't you? If one piece of trim could be installed to cover that transition, that works too. You would probably need to do something fancy at the top end, though... so that the quarter round wouldn't just be square cut on the end. What will your base be doing on the landing?
