Shiplap stagger
Old 05-06-15, 11:02 AM
Shiplap stagger
Hello, I am installing horizontal shiplap on an interior wall. The wall is 18 ft. Shoulld I use 12 ft or 16 ft boards ? How do I stagger ?
Thanks,
Jerry
Old 05-06-15, 02:20 PM
chandler's Avatar
Received 10 Upvotes on 9 Posts
Welcome to the forums! You can use any combination you want as long as your stagger isn't in a detectable pattern (random). Make sure the lumber lands on a stud. If all you have is long lumber, start one run from the right and the next one from the left to keep from bunching your seams on one side.
Old 05-07-15, 04:53 PM
W
Received 66 Upvotes on 57 Posts
Patterns
I personally like patterns. I would make the first course 12' + 6'. Then the second course would be 6' + 12'. Then repeat. The joints would be in a line in every other course. The studs would need to be in the right locations for this to work. Just my 2 cents. This would require 12' stock.
Old 05-08-15, 03:51 AM
Received 871 Upvotes on 762 Posts
I also prefer the random stagger because when the joints line up - it draws your eye to it
