Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Paneling and Trim
Reload this Page >
Base trim with plinth block in tight corner
Old 10-31-15, 03:49 PM
I am installing my own base trim with plinth blocks at the door frames and have reached a difficult doorway. I am not sure how to proceed. Any tips?
Old 10-31-15, 07:05 PM
XSleeper's Avatar
Use 2 plinth blocks to create one wider one. You will want to rip the ogee off of the left side of the plinth so that you can scribe it tight to the wall, and you will want the top ogee to dead end into the wall. So, for example, take two plinth blocks. Rip the ogee off the left side of the first one, then hold it up in the same place you have it now, measuring how wide the filler needs to be. Then cut that piece out of the 2nd plinth block, and glue and nail it to the first one. You will likely need to do a little bit of sanding and painting on the block to make that seam disappear, and most of it will likely be hidden behind the base. Then your baseboard will butt into it with no ugly gap behind, and no need to caulk sculpt.
