Wooden Frame repair
Old 04-09-01, 06:41 PM
Willsem
Angry
I have an old house with a screened in porch. My problem is the base frame has sections of rotted wood. Since the base 2 X 4 spans more than one vertical support, joist, I would just like to repair the area affected. The base piece is about 12 feet long and the effected area is about 3 feet.
Note: The outside lawn over the years is over the base 2X4. The dirt will be removed when I put the new piece back in.
How can I cut out the 3 foot affected area and replace it with new 2 X4. I want to find a way to reconnect the new piece so I have support.
Old 04-11-01, 12:35 PM
Guest
So...you have a partially rotten bottom plate in your screen porch. It spans more than one floor joist. Right?
You SHOULD cut a replacement that will "break" over a joist at each cut end. Make sure that you eliminate ALL rotten wood, or you will be back at this again.
Remember - an 8' 2x4 costs the same as a 6' one.
Old 04-11-01, 12:59 PM
Willsem
Thanks for your reply. The porch is a single story and extends out from the first floor only. It appears that the dirt from the back yard has built up around the base;therfore causing the rot.
Old 04-13-01, 11:48 AM
Mike Swearingen's Avatar
Received 1 Upvote on 1 Post
Cool
Use an 8' pressure-treated 2X4. Get a brand-name or one with an American Wood Preservers Bureau (AWPB) stamp. Most are guaranteed for 50 years.
You can cut the old 2X4 out with a reciprocating saw. Use a metal cutting blade to separate the porch studs from piece that you're replacing.
Install it just as More said (HE's the pro at this.)
Good Luck!
Mike
