Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Paneling and Trim
Reload this Page >
How should I fill large gaps in staircase trim?
Old 11-16-18, 05:52 AM
B
Received 1 Upvote on 1 Post
Size:  96.8 KBName:  IMG_5745.jpg
Size:  101.8 KBName:  IMG_5746.jpg
Size:  96.2 KBWhat is the best way to fill large gaps in our staircase trim? It doesn't have to be perfect but almost anything would look better than it does now. Thanks!
Old 11-16-18, 07:37 AM
Received 868 Upvotes on 759 Posts
The more you can fill with small pieces of wood the better, I'd caulk those pieces in place. Filler would also be an option but it can be hard to make look right and is often prone to cracking.
Old 11-16-18, 08:06 AM
XSleeper's Avatar
Received 1,958 Upvotes on 1,755 Posts
I would probably replace pieces and retrim as needed. Part of the problem is the baseboard is too thin. Add on wood as needed and caulk edges as needed.
