Gap caused by newly removed panels
Old 12-23-19, 12:41 PM
D
I removed some 2 foot paneling off the wall and going to leave it as just drywall. On the corner there is a wood arch that has a gap where the paneling use to be. What should I do with it? Should I fill it with something or cover it with some kind of corner trim.
Old 12-23-19, 01:00 PM
Received 268 Upvotes on 240 Posts
A picture or two would be helpful here.
Old 12-23-19, 01:27 PM
Received 759 Upvotes on 664 Posts
I agree, pics would help us better understand what you have going on.
How to insert pictures.
Old 12-23-19, 06:26 PM
D
http://imgur.com/gallery/sqzzuXx
sorry it took awhile.
Old 12-23-19, 06:32 PM
XSleeper's Avatar
Received 1,749 Upvotes on 1,573 Posts
I would prefill the gap with joint compound. Once it is dry, apply your folded paper tape into the corner (embed in mud and wipe down tight). Once that is dry, finish it with a couple more coats of mud.
Old 12-24-19, 02:18 AM
I agree. Just to clarify - you'd apply a thin coat of mud after the prefill coat has dried so the tape can be embedded in the wet mud.
Old 12-24-19, 03:15 AM
Marq1's Avatar
Received 1,142 Upvotes on 1,035 Posts
Is the area where the lower paneling used to be flush with the upper area or is it recessed?
Old 12-30-19, 08:54 PM
D
Its flush with the upper half
