How to attach trim in vinyl sunroom
Old 11-20-20, 07:03 PM
N
Just had a 4 season vinyl skin sunroom installed. I put down luxury vinyl plank flooring but still need to put quarter round down along the wall. I don’t think I can use nails into this stuff so I to figure out an adhesive. I tried some liquid nails fuze it tonight but it didn’t adhere well at all. Any thoughts?
Old 11-20-20, 07:37 PM
XSleeper's Avatar
Received 790 Votes on 727 Posts
You might have to resort to using glazing tape. Once you have a piece cut to fit, put the glazing tape on the base shoe, do not remove the entire backing... just start to pull a tab, 1" long. Then place the base shoe where it needs to go, hold it in place with one hand while you pull on the backing tab, pushing the bases how down as you go. You will be sticking it to the wall.
If you feel like the top edge should be caulked, you can always do that last.
Old 11-21-20, 06:21 AM
P
Received 750 Votes on 689 Posts
I would use dots of caulk or adhesive to stick the quarter round in place. I've had good luck using Duo-Sil. It's not stocked by big box home centers but a lumber yard or vinyl siding supply company may stock it or you can order it online.
Old 11-21-20, 07:04 AM
Received 159 Votes on 146 Posts
Be sure to clean the area where the glue will be.
