Go Back  DoItYourself.com Community Forums > Interior Improvement Center > Paneling and Trim
Reload this Page >
Wood filler without for damaged door trim ???
Old 04-30-21, 07:01 AM
W
Received 1 Upvote on 1 Post
Door casing around high traffic door is damaged. Is wood filler best to use ??
Old 04-30-21, 09:14 AM
Received 753 Upvotes on 658 Posts
I don't know that one filler is much better than another. The issue is if the trim sees any abuse the filler is apt to pop loose.
Old 04-30-21, 09:21 AM
W
My assumption is damaged was done when they were building the place . I guess I ll just try reg wood filler.
Old 04-30-21, 09:26 AM
Possible although the most likely cause is furniture and stuff being moved thru that doorway.
Old 04-30-21, 02:09 PM
Marq1's Avatar
Received 1,137 Upvotes on 1,031 Posts
For minor patching, like nail holes, drywall compound works fine, I hate caulk, it shrinks and leaves small depressions.
For something larger, i use bondo, wood filler is ok for big voids but not so great for shallow areas!
