door jamb extensions?
Old 12-13-21, 04:01 PM
F
Hi all,
Somewhat of a newbie home DIY'er trying to learn the process and enjoy the journey.
I was wondering if someone would be kind enough to help answer a question about a new patio door that we installed. Attached are some pictures.
My question: am I correct in believing that I need to add jamb extensions to fit and cover the exposed areas so that I can install the trim around the door?
Thank you in advance!
Cheers
Old 12-13-21, 04:10 PM
XSleeper's Avatar
Received 1,749 Upvotes on 1,573 Posts
Well that's about all you CAN do now that it's installed. Normally you would order a door that is the right wall thickness for your wall so that you don't need to do anything unusual. Typically if you have to add a jamb extension, you do it on the OUTSIDE so that the interior jamb, hinges and threshold can all be flush with the interior wall surface.
