Question Please Help
Old 07-09-01, 04:33 PM
Guest
We biught our house 4 years ago and the neighbors said that the siding was put on two years before that
Well we have white aluminum siding and if you rub up against it the white comes off is that normal this is our first house and if its not normal how do I fix it.
Please help
White in Missouri
Jenn
Old 07-10-01, 05:45 AM
fewalt's Avatar
Jenn,
For some reason your paint has oxidized to some degree. Try to find your cleaning instructions and warranty. You should be able to clean it with a siding wash and soft bristle brush. This should remove the oxidation. If the paint has peeled totally off anywhere, then you have a warranty problem.
fred
