T&G over plaster wall
's Avatar
09-03-01, 08:28 AM   #1
Help! We have sewage coming up into the yard from a drain pipe (or possibly it is a vent pipe? It is an open white pvc pipe that comes up into the front yard near the house). What would cause this? Is it something that can be easily fixed by (very) novice homeowners or are we better off calling a plumber?
Some info that might help in answering my question:
1. We have had alot of rain over the past week
2. We have had a problem in the past with the toilets flushing poorly, but the problem resolved on it own.
Thanks for your help.
's Avatar
02-04-02, 06:01 PM   #2
Looking to put thin tongue and groove panelling over plaster wall that has cracked and been repaired many times. The contractor wants to run it diagonally so there is more support which I understand. But, what if the wall starts to crack and chip away behind panelling? Is there any need for concern here? Should he install furring strips anyways? Should he use liquid nails and the nail or scew it on?
Thank you in advance for a reply.
Eric
