miter cut for unsquare corner
jandrewnels's Avatar
02-19-02, 05:48 PM   #1
jandrewnels
I'm feeling a little challenged installing some base molding on an out-of-square outside
corner. The corner is more like 92 or 93 deg. so my understanding is that would require a
bevel setting that goes beyond the 45 deg. limit of my miter saw. Any suggestions would be greatly
appreciated.
Thanks,
JA
George's Avatar
VA
02-19-02, 06:10 PM   #2
JA:
If you put the molding in your miter box upside down and backwards the 45 limit will serve as a starting point for angles over 90 degrees. As you bring the blade to what would normally be considered 'less' than 45, you're actually cutting greater than 45.
A T-bevel (from a good hardware store) will allow you to measure the exact angle of your cut...
