1X6 Pine Beadboard
1X6 Pine Beadboard
I wish to put 1x6 pine beadboard along my stairs and on the front wall entering my home. These boards will run at a 45 degree angle. I need a suggestion on how to get started, whether I should start at the bottom by the staircase and run that angle all the way up, or start in the middle and work in both directions. Any suggestions would be appreciated.
Unless you have an unusually steep set of stairs, a 45 degree angle on the stairway paneling is going to look a little strange. Stairs are normally set at a 7/12 pitch, which is less than 30 degrees...
