Plywood grade for 1/2 furring/backerboard
stnaxe's Avatar
03-12-02, 09:48 AM   #1
I'm furring out a wall 1/2 inch for my plumbing wall. I need to use part of the plywood as backerboard for a pedistal sink. I'm planning to screw or nail the 1/2 inch plywood to an existing 2x8 which is now being used as the existing backerboard for the sink . I plan to sheetrock over the 1/2 inch plywood with 1/2" sheetrock which will add 1 inch to the existing wall. My question is what kind of plywood grade should I use for this?
fewalt's Avatar
VA
03-12-02, 11:18 AM   #2
stnaxe,
You can use any kind of ply, but I would use 'greenboard' for behind a sink. It has a bit more water repellency than sheetrock.
fred
tedn332's Avatar
03-12-02, 11:22 AM   #3
tedn332
Use a piece of 7/16 OSB [waferboard]. It is cheaper and more stable than 1/2 inch plywood you buy now days. If 7/16 isn't enough, you will have to go to 5/8.
